ElasticSearch-Spring bean creation Issue while building java code using Gradle
Hi Folks,
I am facing below issue while executing Gradle build.
Can you please let me know your thoughts to fix below issue.
2019-08-16 21:41:29.874 ERROR 37147 --- [ost-startStop-1] o.s.b.web.embedded.tomcat.TomcatStarter  : Error starting Tomcat context. Exception: org.springframework.beans.factory.BeanCreationException. Message: Error creating bean with name 'servletEndpointRegistrar' defined in class path resource [org/springframework/boot/actuate/autoconfigure/endpoint/web/ServletEndpointManagementContextConfiguration.class]: Bean instantiation via factory method failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.springframework.boot.actuate.endpoint.web.ServletEndpointRegistrar]: Factory method 'servletEndpointRegistrar' threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'healthEndpoint' defined in class path resource [org/springframework/boot/actuate/autoconfigure/health/HealthEndpointConfiguration.class]: Bean instantiation via factory method failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.springframework.boot.actuate.health.HealthEndpoint]: Factory method 'healthEndpoint' threw exception; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'org.springframework.boot.actuate.autoconfigure.elasticsearch.ElasticsearchHealthIndicatorAutoConfiguration$ElasticsearchClientHea
BUILD.GRADLE:
dependencies {
    compile('org.elasticsearch:elasticsearch:6.2.3')
    compile('org.elasticsearch.client:elasticsearch-rest-high-level-client:6.2.3')
    compile('org.elasticsearch.client:transport:6.2.3')
    compile('org.springframework.boot:spring-boot-starter-actuator')
    compile('org.springframework.boot:spring-boot-starter-data-elasticsearch')
    compile('org.springframework.boot:spring-boot-starter-web')
    compile('org.apache.avro:avro:1.8.2')
    testCompile('org.springframework.boot:spring-boot-starter-test')
POM.XML:
    <parent>
        <groupId>org.springframework.boot</groupId>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.0.0.RELEASE</version>
    </parent>
Thanks,
Ajay.
Welcome!
Please format your code, logs or configuration files using </> icon as explained in this guide and not the citation button. It will make your post more readable.
Or use markdown style like:
CODE
This is the icon to use if you are not using markdown format:
There's a live preview panel for exactly this reasons.
Lots of people read these forums, and many of them will simply skip over a post that is difficult to read, because it's just too large an investment of their time to try and follow a wall of badly formatted text.
If your goal is to get an answer to your questions, it's in your interest to make it as easy to read and understand as possible.
Please update your post.
When using springboot with
elasticsearch, you need to be explicit with some transitive dependencies as SpringBoot declares a version 6.4...
Basically you can put this in your pom.xml:
<properties>
  <elasticsearch.version>7.3.0<elasticsearch.version>
</properties>
See documentation here: https://docs.spring.io/spring-boot/docs/current/reference/html/howto-build.html#howto-customize-dependency-versions
