I have installed ES 5.0.0 Alpha 3 and try to start it up. However, it gives me the following result.
Error: missing `server' JVM at `C:\Program Files (x86)\Java\jre1.8.0_91\bin\server\jvm.dll'.
Please install or use the JRE or JDK that contains these missing components.
It didn't happen to my another version of ES. Is there any errors for it?
does this work now? This seems to be a problem with Oracle JRE on Windows. The respective page says:
jre\bin\server\
On Microsoft Windows platforms, the JDK includes both
the Java HotSpot(TM) Server VM and Java HotSpot Client VM.
However, the Java SE Runtime Environment for Microsoft Windows
platforms includes only the Java HotSpot Client VM. Those wishing
to use the Java HotSpot Server VM with the Java SE Runtime
Environment may copy the JDKs jre\bin\server folder to a
bin\server directory in the Java SE Runtime Environment. Software
vendors may redistribute the Java HotSpot Server VM with their
redistributions of the Java SE Runtime Environment.
I suggest you just install a JDK. Then you should be fine (or you use the workaround they suggest).
Daniel
