FATAL [index_not_found_exception] no such index [.kibana_task_manager], with { resource.type="index_or_alias" & resource.id=".kibana_task_manager" & index_uuid="_na_" & index=".kibana_task_manager" }
Hi am facing this error FATAL [index_not_found_exception] no such index [.kibana_task_manager], with { resource.type="index_or_alias" & resource.id=".kibana_task_manager" & index_uuid="na" & index=".kibana_task_manager" }
am using 3 elasticsearch on RHEL and 1 Kibana but while running kibana facing this issue below is my kibana.yml
server.port: 5601
server.host: "xx.xxx.xxx.xx"
elasticsearch.hosts: ["http://xx.xxx.xxx.xxx:9200" , "http://xx.xxx.xxx.xxx:9200" , "http://xx.xxx.xxx.xxx:9200"]
logging.dest: /home/Elasticsearch/logs/kibana.log
logging.verbose: false
can I have more details, Logs and your conf.yml. What happened before the exception ?
and do you start the kibana with the admin privileges ??
cc @tsullivan
Rashmi.
Thanks for the quick response Rashmi , so simply running kibana as ./bin/kibana and didnt gets any exception if provides single elasticsearch host and working properly for that ..but as gives 3 hosts then only getting this warnings
@tylersmalley - any inputs here?
Rashmi
Hey resolved the issue now in my case the problem was ES cluster was not working correctly but if anyone facing the same issue then can be removed by deleting the index from ES like
curl -XDELETE http://localhost:9200/.kibana*
Thank You!
