Geo_shape field for document index not showing on map for polygons
Hello.
I am trying to display geo_shape polygon data on a Kibana map, using a document index. The map seems to be loading successfully as it zooms to where the polygon should be but there is no polygon drawn.
I have created a simple test:
PUT /polytest
  "mappings": {
    "properties": {
      "location": {
        "type": "geo_shape"
and then pushed some data to it:
POST polytest/_doc
  "location":  {
      "coordinates": [
            -0.076722,
            51.516602
            -0.076712,
            51.516626
            -0.076529,
            51.51668
            -0.07632,
            51.516478
            -0.076521,
            51.516429
            -0.076722,
            51.516602
      "type": "Polygon"
Using Kibana, I added a new map (Kibana -> Maps -> Create Maps)
Added layer -> Documents -> polytest
Is there an issue showing polygon data from a geo_shape field in a document index, or am I doing something wrong?
Thanks,
Mark
What version of Kibana are you running?
I was able to follow the steps you provided and display the polygon in Maps. Below are the steps I took
  • PUT polytest index mappings
  • POST polytest document you provided
  • Created a kibana index pattern for polytest
  • Created a new map and added a document layer from polytest
  • Clicked fit to bounds to zoom in to data bounds.
Can you see the polygon if you zoom into the area around it?
