Hi
I have a test system for ELK using VirtualBox and Docker with 4 virtual cpu cores.
I've managed to enable metricbeat in a container with the docker module enabled (only this module) and I am receiving readings from the docker infrastructure, all seems ok.
It shows strange readings for cpu where values cpu usage raises as up as 300% and more.
I don't know how to interpret these readings. Are they wrong? Is that the sum off all 4 cores? Can I add some kind of automatic correction for these values?
Thank you!
