HELP ! Upgrade ES 6.7.0 to 7.1.0
[2019-06-18T14:45:27,595][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [eta10] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: ElasticsearchException[failed to bind service]; nested: WriteStateException[failed to write state to the first location tmp file /var/lib/elasticsearch-7/nodes/0/node-63.st.tmp]; nested: AccessDeniedException[/var/lib/elasticsearch-7/nodes/0/_state/node-63.st.tmp];
        at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:163) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:150) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:86) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:124) ~[elasticsearch-cli-7.1.0.jar:7.1.0]
        at org.elasticsearch.cli.Command.main(Command.java:90) ~[elasticsearch-cli-7.1.0.jar:7.1.0]
        at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:115) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:92) ~[elasticsearch-7.1.0.jar:7.1.0]
Caused by: org.elasticsearch.ElasticsearchException: failed to bind service
        at org.elasticsearch.node.Node.<init>(Node.java:582) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.node.Node.<init>(Node.java:252) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.bootstrap.Bootstrap$5.<init>(Bootstrap.java:211) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:211) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:325) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:159) ~[elasticsearch-7.1.0.jar:7.1.0]
        ... 6 more
Caused by: org.elasticsearch.gateway.WriteStateException: failed to write state to the first location tmp file /var/lib/elasticsearch-7/nodes/0/node-63.st.tmp
        at org.elasticsearch.gateway.MetaDataStateFormat.writeStateToFirstLocation(MetaDataStateFormat.java:127) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.gateway.MetaDataStateFormat.write(MetaDataStateFormat.java:243) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.gateway.MetaDataStateFormat.writeAndCleanup(MetaDataStateFormat.java:185) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.env.NodeEnvironment.loadOrCreateNodeMetaData(NodeEnvironment.java:411) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.env.NodeEnvironment.<init>(NodeEnvironment.java:302) ~[elasticsearch-7.1.0.jar:7.1.0]
        at org.elasticsearch.node.Node.<init>(Node.java:272) ~[elasticsearch-7.1.0.jar:7.1.0]
        ... 6 more
Caused by: java.nio.file.AccessDeniedException: /var/lib/elasticsearch-7/nodes/0/_state/node-63.st.tmp
        at sun.nio.fs.UnixException.translateToIOException(UnixException.java:90) ~[?:?]
        at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111) ~[?:?]
        at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116) ~[?:?]
        at sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:215) ~[?:?]
        at java.nio.file.spi.FileSystemProvider.newOutputStream(FileSystemProvider.java:478) ~[?:?]
        at java.nio.file.Files.newOutputStream(Files.java:219) ~[?:?]
        at org.apache.lucene.store.FSDirectory$FSIndexOutput.<init>(FSDirectory.java:411) ~[lucene-core-8.0.0.jar:8.0.0 2ae4746365c1ee72a0047ced7610b2096e438979 - jimczi - 2019-03-08 11:58:55]
Some part of my error code. No idea how should I do after I have changed "sudo chmod a+rwx" to the files and dir.
Check the file permissions / file owners again. Command you issued "sudo chmod a+rwx" is not secure and is not recursive.
From your log
Elasticsearch cannot write data to
You know problem.. More about permissions on Linux OS you can read there.
Hi Vasek, is there a way i can make changes to all required files and directory that are required by ES? Can share the command ? thanks
I have already posted it: HELP ! Upgrade ES 6.7.0 to 7.1.0
But be aware of name of directories. It may vary.
e.g.:
/var/lib/elasticsearch != /var/lib/elasticsearch-7
I have tried this. but is not working. Are you referring to this command ?
Please, read your logs.
I don't see /var/lib/elasticsearch but there is /var/lib/elasticsearch-7.
See HELP ! Upgrade ES 6.7.0 to 7.1.0
Hi yes, this is what I try to do so that I wont confused with the old and new folders to refers to. Or are you trying to tell me I cannot use folders with other name than elasticsearch ?
Regarding the logs, I have granting full access to everyone to access that, but this is still throwing me error.
-rw-rw-r-- 1 elasticsearch elasticsearch 0 Jun 14 15:05 wazuh-es_index_search_slowlog.json
I realized changing the ownership does not really help. with this chown -R.
Hi all, I have the following users in my server now. These are the users which will be involved in this running of Elasticsearch.
  • Root (creation of system files)
  • Luke account ( running / executing commands to run ES) ID: 1000
  • Elasticsearch account (Owner of the elasticsearch folders and files, but this account does not have a physical /home space. ) ID: 121
May I know in this scenario, what rights or access should I give to the above?
Dear all, when I try to run : systemctl start elasticsearch, the following msg triggers me to think. Where is this file and I cant find it.
ExecStart=/usr/share/elasticsearch/bin/elasticsearch -p ${PID_DIR}/elasticsearch.pid --quiet
I do have this valid file and directory : /usr/share/elasticsearch/bin/elasticsearch
but there is no "elasticsearch.pid" on the server. May I know how do I resolve this? Do I need to create this .pid file ?
[2019-06-19T16:49:28,710][INFO ][o.e.e.NodeEnvironment    ] [eta10] using [1] data paths, mounts [[/ (/dev/mapper/vg--root-lv--root)]], net usable_space [1.9tb], net total_space [2tb], types [ext4]
I notice there is a line in the log stating the above, may I know what does it refers? Does the mapping to the root directory? Can I change it since I am not using the root account to run the ES.
