Dear all,
I have a problem with a rollover for a metric beat index.
I created a ILM Policy I setup metric beat to send data as follow:
setup.ilm.check_exists: false
setup.ilm.overwrite: true
setup.ilm.enabled: true
setup.template.overwrite: true
setup.ilm.pattern: "{now/d}-000001"
setup.ilm.policy_name: "metricbeat-test"
GET /metricbeat-*/_ilm/explain
I have:
"metricbeat-7.9.0" : {
"index" : "metricbeat-7.9.0",
"managed" : true,
"policy" : "metricbeat-test",
"lifecycle_date_millis" : 1609840383887,
"age" : "12.53m",
"phase" : "hot",
"phase_time_millis" : 1609840385090,
"action" : "rollover",
"action_time_millis" : 1609840468717,
"step" : "ERROR",
"step_time_millis" : 1609841067798,
"failed_step" : "check-rollover-ready",
"is_auto_retryable_error" : true,
"step_info" : {
"type" : "illegal_argument_exception",
"reason" : "index.lifecycle.rollover_alias [metricbeat] does not point to index [metricbeat-7.9.0]",
"stack_trace" : """java.lang.IllegalArgumentException: index.lifecycle.rollover_alias [metricbeat] does not point to index [metricbeat-7.9.0]
at org.elasticsearch.xpack.core.ilm.WaitForRolloverReadyStep.evaluateCondition(WaitForRolloverReadyStep.java:114)
at org.elasticsearch.xpack.ilm.IndexLifecycleRunner.runPeriodicStep(IndexLifecycleRunner.java:174)
at org.elasticsearch.xpack.ilm.IndexLifecycleService.triggerPolicies(IndexLifecycleService.java:327)
at org.elasticsearch.xpack.ilm.IndexLifecycleService.triggered(IndexLifecycleService.java:265)
at org.elasticsearch.xpack.core.scheduler.SchedulerEngine.notifyListeners(SchedulerEngine.java:183)
at org.elasticsearch.xpack.core.scheduler.SchedulerEngine$ActiveSchedule.run(SchedulerEngine.java:216)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
at java.base/java.lang.Thread.run(Thread.java:832)
"phase_execution" : {
"phase_definition" : {
"min_age" : "0ms",
"actions" : {
"rollover" : {
"max_size" : "50gb",
"max_age" : "30d"
"version" : 616649,
"modified_date_in_millis" : 1609840384048
Does anyone have a solution or a hint?
best regards
