hello, i'm trying to update my index.max_result_window using put to here with the following body:
http://<my_url>:9200/.kibana/_settings PUT { "index" : { "max_result_window" : 2147483647 } }
it returns: {acknowledged : true}
but when i try and run my command i still get this error when using the api:
Result window is too large, from + size must be less than or equal to: [10000] but was [10004]. See the scroll api for a more efficient way to request large data sets. This limit can be set by changing the [index.max_result_window] index level parameter.
as if my updated settings did not change anything.
I also restarted the ELK stack with no luck.
Any Ideas? i've Googled everywhere and it seems like the settings update should've worked as expected?
My version of Kibana is:
Version	4.3.1
Build	9517
Commit SHA	d6e412d
any help would be appreciated. thanks,
Brandon
