Index.refresh_interval problem,Please help
I change this configuration
index.refresh_interval:1
With totally the same others configuration
index TPS is 11346
index.refresh_interval:5
index TPS is 13648
But problem is When I remove this configuration
index TPS is 21980
If I remove this configuration the "index.refresh_interval",the default
value should be 1,
am I right?
But why I set it to 1,the TPS is so different?
What is TPS? How are you setting and removing this value? I don't think
Elasticsearch supports removing values.
But yes, the default value is 1.
Ivan
index TPS is 11346
index TPS is 13648
index TPS is 21980
value should be 1,
am I right?
TPS is index rate,removing means I remove it from configuration file,sorry.
I find the unit of this configuration is millis,not secs
thanks
2013/4/9 Ivan Brusic ivan@brusic.com
Ivan
index TPS is 11346
index TPS is 13648
index TPS is 21980
value should be 1,
am I right?
You received this message because you are subscribed to a topic in the
To unsubscribe from this topic, visit
https://groups.google.com/d/topic/elasticsearch/-EpE9Wxn0b8/unsubscribe?hl=en-US
To unsubscribe from this group and all its topics, send an email to
