I have a cluster on version 7.17 where I'm using a node attribute called node_type with the values hot and warm to allocate shards and move between node type with ILM, all indices have an index.routing.allocation.require.node_type: "hot" setting in the template and this work as expected.
Recently I'm starting to create a new cluster on 8.4 and decided to use the native data_tier role to allocate shards and move between the nodes with ILM, I have nodes that only have the role data_hot and notes that have the role data_warm and data_content.
The documentation says that _tier is a supported attribute for the index.routing.allocation.require.{attribute} setting, so I used the following setting in my template.
index.routing.allocation.require._tier: "data_hot"
But when I try to creat an index, the cluster went red because it was not able to allocate any shard, using the allocation explain API I got the following response.
"node_id": "QUc9-REDACTED",
"node_name": "HOT-NODE",
"transport_address": "REDACTED:9300",
"node_attributes": {
"xpack.installed": "true"
"node_decision": "no",
"weight_ranking": 1,
"deciders": [
"decider": "filter",
"decision": "NO",
"explanation": """node does not match index setting [index.routing.allocation.require] filters [_tier:"data_hot"]"""
"decider": "data_tier",
"decision": "NO",
"explanation": "index has a preference for tiers [data_content] and node does not meet the required [data_content] tier"
It says that the node with the data_hot role does not match the setting _tier: data_hot, which is not true.
"QUc9-REDACTED": {
"name": "HOT-NODE",
"host": "REDACTED",
"ip": "REDACTED",
"version": "8.4.2",
"build_flavor": "default",
"build_type": "rpm",
"build_hash": "89f8c6d8429db93b816403ee75e5c270b43a940a",
"total_indexing_buffer": 3221225472,
"roles": [
"data_hot",
"ingest",
"remote_cluster_client"
"attributes": {
It also has a _tier_preference for a data_content role node, whic the hot node does not have, but the warm node has this role.
In the warm node the allocation explain is the following:
"node_id": "IElT-REDACTED",
"node_name": "WARM-NODE",
"weight_ranking": 4,
"deciders": [
"decision": "NO",
If I add the setting index.routing.allocation.include._tier_preference: "data_hot" the shard will then be allocated to the hot nodes.
But I want this to work with the require setting as it work when using a custom attribute.
What is the issue here? Is this a bug? Is the documentation wrong and the _tier is not supported?
