Is it possible for buckets_path to reference a scripted_metric aggregation?
I am working on the kibana_sample_data_logs index. I ran the following aggregation:
GET kibana_sample_data_logs/_search?size=0
    "match_all": {}
  "aggs": {
    "doc_buckets_for_terms_aggregation": {
      "terms": {
        "field": "clientip"
      "aggs": {
        "max_bytes": {
          "scripted_metric": {
            "init_script": "state.max_bytes = 0L;",
            "map_script": """
              def current_bytes = doc['bytes'].getValue();
              if (current_bytes > state.max_bytes)
                {state.max_bytes = current_bytes;}
            "combine_script": "return state",
            "reduce_script": """
              def max_bytes = 0L;
              for (s in states) {if (Objects.isNull(s)){max_bytes=max_bytes} else if (s.max_bytes > (max_bytes))
                {max_bytes = s.max_bytes;}}
              return max_bytes
    "max_buckets_whole_index": {
      "max_bucket": {
        "buckets_path": "doc_buckets_for_terms_aggregation>max_bytes"
In this snippet above, we first bucket documents on the clientip. Next we run a scripted_metric aggregation to calculate the max_bytes field for each bucket (meaning for each clientip). Finally, we calculate the max_bytes for the whole index by running the max_bucket aggregation.
But I am getting the following error:
  "error" : {
    "root_cause" : [ ],
    "type" : "search_phase_execution_exception",
    "reason" : "",
    "phase" : "fetch",
    "grouped" : true,
    "failed_shards" : [ ],
    "caused_by" : {
      "type" : "aggregation_execution_exception",
      "reason" : "buckets_path must reference either a number value or a single value numeric metric aggregation, got: [InternalScriptedMetric] at aggregation [max_bytes]"
  "status" : 500
It seems that it is not possible for buckets_path to reference a scripted metric.... How do I change my script so that it works ? Thanks in advance...
