Is there a way to include custom d3 charts in kibana 4?
It's not difficult (once you spend hours and hours figuring it out).
You have to play around with the FilterManager, for instance, on the controller.
Example:
var filterManager = Private(require('ui/filter_manager')); // Add filterManager.add('myField', '0', '', 'myindex'); // Remove filterManager.remove('myField', '0')
If you want to interact with the Filter Bar:
var queryFilter = Private(require('ui/filter_bar/query_filter')); // Then, get all filters queryFilter.getAppFilters()
Maybe I make it sound easier than it its, but I struggled with this for a couple of hours.
Good Luck
Thank you. I have been trying to find this solution as well. it helps a lot.
@JuanCarniglia, do you have any examples that run on Kibana 5.0 as well?
I'm working on that, there are some changes. I'll let you know as soon as I
get to it.
@tbragin: Is the code for spalger_guage on github? Around 31 minutes into video 'fast forwards' from empty vis_type.js into a fully coded up version. Would be great if I can see the code.
kibana Gauge plugin (with pointer)
Kibana tree plugin (D3.js)
hey plz i m working with kibana 5.1.2 and i need a custom visualization that i want to create with a plugin can anyone help me with documentation or smthg i don t khow how to create it or anything
thanks
