I was trying the settings to block data writes and also metadat writes to
an index applying this:
curl -XPUT 'http://testserver:9200/test_index/_settings ' -d '{
"index.blocks.read_only" : "true"
which works fine but now I would like to remove this index and I'm facing
this issue;
{"error":"RemoteTransportException[[lonsl1101844-master][inet[/10.243.1.10:9300]][indices:admin/delete]];
nested: ClusterBlockException[blocked by: [FORBIDDEN/5/index read-only
(api)];]; ","status":403}
I can't change anymore the configuration of the index as metdata writes are
forbidden.
I also now have an issues with my different monitoring tools as they are
using get _settings/_aliases.. request which are forbidden for this index.
Could you please indicate me how I can force the remove of this index or
change its configuration?
Thanks,
Nicolas
To unsubscribe from this group and stop receiving emails from it, send an email to elasticsearch+unsubscribe@googlegroups.com .
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/06aaed45-0208-4e4f-8c3e-d58adf93a388%40googlegroups.com .
For more options, visit https://groups.google.com/d/optout .
warkolm
(Mark Walkom)
January 29, 2015, 9:45pm
#2
Just set that value to false and you should be good to go.
On 29 January 2015 at 23:58, 'Nicolas Fraison' via elasticsearch <
elasticsearch@googlegroups.com > wrote:
this issue;
are forbidden.
Thanks,
Nicolas
https://groups.google.com/d/msgid/elasticsearch/06aaed45-0208-4e4f-8c3e-d58adf93a388%40googlegroups.com?utm_medium=email&utm_source=footer
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAEYi1X9XmE8unKH9JYz1r9CvyXO5A8%3DpGkeoXTMWBdQQz0S4cQ%40mail.gmail.com .
BradVido
(BradVido)
April 2, 2015, 1:55pm
#3
I have the same problem. You can't change the value to false because
metadata udpates are blocked and changing the value is itself a metadata
update!
Is there any way to delete this index now!?
elasti...@googlegroups.com <javascript:>> wrote:
this issue;
are forbidden.
Thanks,
Nicolas
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/5f5f576a-bf33-44af-b671-e616b40e91af%40googlegroups.com .
If I remuer well the isssue of setting back the read-only setting to false was due to the fact that I was performing a Put instead of a post or the opposite.
Let me know if it help you, if no I will look at some old scripts that I should have kept with this.
Nicolas
jeudi, 02 avril 2015, 03:55PM +02:00 de BradVido bradyvidovic@gmail.com :
I have the same problem. You can't change the value to false because metadata udpates are blocked and changing the value is itself a metadata update!
On 29 January 2015 at 23:58, 'Nicolas Fraison' via elasticsearch < elasti...@googlegroups.com > wrote:
I was trying the settings to block data writes and also metadat writes to an index applying this:
curl -XPUT
' http://testserver:9200/test_index/_settings ' -d ' {
which works fine but now I would like to remove this index and I'm facing this issue;
I can't change anymore the configuration of the index as metdata writes are forbidden.
I also now have an issues with my different monitoring tools as they are using get _settings/_aliases.. request which are forbidden for this index.
Could you please indicate me how I can force the remove of this index or change its configuration?
Thanks,
Nicolas
To unsubscribe from this group and stop receiving emails from it, send an email to elasticsearc...@googlegroups.com .
You received this message because you are subscribed to a topic in the Google Groups "elasticsearch" group.
To unsubscribe from this topic, visit https://groups.google.com/d/topic/elasticsearch/JkGihq3zcQw/unsubscribe .
To unsubscribe from this group and all its topics, send an email to elasticsearch+unsubscribe@googlegroups.com .
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/1427989358.488102988%40f12.my.com .
