Issue with index - set fielddata=true
When working with my dashboards I got this error message:
"Text fields are not optimised for operations that require per-document field data like aggregations and sorting, so these operations are disabled by default. Please use a keyword field instead. Alternatively, set fielddata=true on [rule.id] in order to load field data by uninverting the inverted index. Note that this can use significant memory."
I try to update that field with:
PUT my-index/_mapping
  "properties": {
    "rule.id": {
      "type":     "keyword",
      "fielddata": true
I got as a result:
  "error" : {
    "root_cause" : [
        "type" : "mapper_parsing_exception",
        "reason" : "unknown parameter [fielddata] on mapper [id] of type [keyword]"
    "reason" : "Failed to parse mapping [_doc]: unknown parameter [fielddata] on mapper [id] of type [keyword]",
    "caused_by" : {
  "status" : 400
I checked and this field's type is text, keyword.
Is that the reason I cannot update the fielddate to true?
Any ideas how to solve that?
Regards,
P
2 points.
  1. You can't change existing mappings (possibly {"rule.id": {"type": "text"}}).
  2. {"fielddata": true} is a parapeter for only text field.
Please try,
  "properties": {
    "rule.id": {
      "type":     "text",
      "fielddata": true
