Hi, I just signed up this morning for the Observability Fundamentals class and am running into issues trying to set the lab up. I followed the initial instructions to log into strigo and the machine appeared to start and give me a functional terminal. Once I got to the next step to copy the public DNS into a new tab and follow the instructions I was greeted with a CONNECTION_REFUSED error. I am not sure how to proceed. I looked at several other posts and it appears that most of them were only resolved with a reset of their training environment.
Hey Greg,
I am assuming you open Strigo and copied the aws URL into a new tab. If that is the case, the URL changes every time your lab stops and resume. Did you use the latest URL? Can you try it again and let me know what happens.
I just resumed my session and tried the fresh url with the same CONNECTION_REFUSED result. I have also tried rebooting the machine several times with the same result.
Thank you for your patience and for trying different options. There was indeed an error with your instance. I have fixed it and will open an internal issue about it, so others don't have the same problem. Let me know if you have any other issues.
