I'm having problem displaying the "count" metric for my logstash data. Kibana/discover and elasticsearch marvel show plenty of entries in today's index. However, the "count" against the "logstash-*" index pattern over a lookback of "Today" results in "No Results Found".
Given that discover clearly shows there are entries in the index for today can someone help me understand why the count metric isn't returning a result?
If I understand correctly, you're using the metric vis and not getting any results. That's very odd.
The only thing I can think is that maybe the time field you've set up is wrong... but I'm probably wrong about that. Can you post a screenshot from both discover and visualize so I can get a better idea of what you're doing?
