Kibana index pattern, matching index, how to match more than 100
elasticsearch version: 7.5.1
kibana version: 7.5.1
I have more than 300 indexes. How to use one index pattern to match all of them? When I enter the "pro" index pattern, it shows that 100 indexes are matched, but 300 indexes cannot be matched. This is just a display problem or need to modify the parameters
Hi and welcome to our community
So all your indices are labeled with the prefix pro, and you expect more 100 to be matched when you're creating them?
Thx & Best,
Matthias
hi, yes, I want to match more indexes
This might be an issue in the index pattern editor, but generally, when you are using this index pattern e.g. in Discover, all indices should be matched
Thank you very much for your answer
