Kibana is not allowing to select data of more than 35 days, for Predictions using Machine Learning
Hello all whenever I select more than 35 days of data in Machine Learning feature for the predictions then it is not allowing me to do this? I want to ask that why is this so? Is this the restriction of ML model of Kibana or anything else.
Could you share the exact error message you are getting from Kibana?
It could be that this error is due to insufficient historical data. Then it would look sth like: Unable to accurately forecast for the full requested time interval.
BTW, which version of the stack you are using?
