Kibana problem with privileges - 7.0 - [FORBIDDEN/12/index read-only / allow delete (api)]
I was upgrading from 6.7 to 7.0 and I have this problem on kibana:
Error registering Kibana Privileges with Elasticsearch for kibana-.kibanax: [cluster_block_exception] blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];"}
What can I do?
I was trying to do "read_only_allow_delete": "false" or "read_only_allow_delete": null, but no success. I still have space in my machine.
I had the xpack installed and with the upgrade this happens.
Thank you.
Hey @Francisca_Lima,
Can you post the output of GET .kibanax/_settings?
How did you try to set read_only_allow_delete? Should be something like:
PUT .kibanax/_settings
  "index": {
    "blocks": {
Yes. I think it is a problem of my license of xpack. Because I tried with xpack not enabled and elasticsearch started with no problem. Thank you, I will try to talk with the support team of ELK about my license.
Hİ @Larry_Gregory ,
My license is basic. I have'nt a security section under Management, in Kibana. I tried this, but stiil haven't security section.
  "index": {
    "blocks": {
I am not defining role. How do I enable xpack?
Kibana version is 7.0.1
Thank you.
