Mapping conflict for system.process.cpu.system+user when using metricbeat-6.3.0 and 6.6.0
I got a mapping conflict in Kibana index patterns due to different templates definitions for same field provided during beat installation.
How can I fix that?
How will you handle this with ECS?
@kaem2111 Sorry for the late response. The easiest way is to delete the existing two templates and create a fresh new one. I see in Metricbeat 6.3.2 upgrade breaks?, there is also a way to actually preserve data if that will be more helpful.
@Kaiyan_Sheng Unfortunaly the hint doesn't help, because I have still installed Metricbeat agent for both release in parallel (see above: both indices are from same day).
If I remember correclty, you wanted to be compatible within all minor releases and even the next major release.
Does this mean, I have to upgrade all 'old' beat agents to get rid of this conflict?
Will this issue be obsolete, when using ECS?
