Metribeat module system output to elasticsearch with incorrect period
I set my metricbeat system module output to elasticsearch hosts('192.168.2.1:9200', '192.168.2.2:9200') with 5s period.
But elasticsearch seems save data every ten seconds:
Here's my metribeat.yaml:
- module: system
  period: 5s
  metricsets:
    - cpu
    #- load
    - memory
    #- fsstat
    #- network
    #- process
    #- process_summary
    #- core
    #- diskio
    #- socket
  processes: ['.*']
  process.include_top_n:
    by_cpu: 5      # include top 5 processes by CPU
    by_memory: 5   # include top 5 processes by memory
- module: system
  period: 5s
  metricsets:
    #- filesystem
    - fsstat
  processors:
    - drop_event.when.regexp:
       system.filesystem.mount_point: '^/(sys|cgroup|proc|dev|etc|host|lib)($|/)'
#- module: system
#  period: 15m
#  metricsets:
#    - uptime
Is ther any way to fix it? Thank you for your help.
Could you please share your full config as text formatted using </>?
Sorry for that. Here is the metricbeat.yml content:
#==========================  Modules configuration ============================
metricbeat.config.modules:
  path: ${path.config}/modules.d/system.yml
  reload.enabled: false
  #reload.period: 10s
  #- module: system
  #  metricsets:
  #    - cpu
  #  enabled: true
  #  period: 1s
#==================== Elasticsearch template setting ==========================
setup.template.settings:
  index.number_of_shards: 1
  index.codec: best_compression
  #_source.enabled: false
setup.template.name: "metricbeat"
setup.template.pattern: "metricbeat-*"
#================================ General =====================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
# Optional fields that you can specify to add additional information to the
# output.
#fields:
#  env: staging
#output.elasticsearch:
#  host: ["http://localhost:9200"]
#  index: "metricbeat-test-{+yyyy.MM.dd}"
#================================ Outputs =====================================
#================================ Process =====================================
processors:
  - drop_fields:
      fields: []
  hosts: ["192.168.2.1:9200", "192.168.2.2:9200"]
  index: "metricbeat-%{[beat.version]}-%{+yyyy.MM.dd}"
  # Optional protocol and basic auth credentials.
  #protocol: "https"
  #username: "elastic"
  #password: "changeme"
${path.config} located at ./modules.d. And here is ${path.config}/modules.d/system.yml content:
- module: system
  period: 5s
  metricsets:
    - cpu
    - memory
  processes: ['.*']
- module: system
  period: 5s
  metricsets:
    - fsstat
  processors:
#- module: system
#  period: 15m
#  metricsets:
#    - uptime
Metribeat version is '6.2.4', I installed metribeat on ubuntu 16 server by apt-get command.
Thank you for your help!
