I want to monitor a multi cpu system and set up the systems metricbeat to get the values. The problem is the systems metric beat reports a cumulative metric for all the CPUs. I want to report the values of all the CPUs separately. Is there a way to do this?
Hi Siddhant_Gupta!
The core metricset should have what you're looking for. It's not enabled by default but you can enable it in your metricbeat configuration.
