Multiple ELK stacks on same hardware and within same OS
hi sorry for the repost of basically this one
my reason for asking is that i need to protect data in a seperate ELK installation from the other ELK installed on the same (very powerfull hardware)
from what i can see in the above link, this is technically feasable with using different ports, my question is about the ram and java part. if i have 64GB+ ram, will it be smooth sailing, as long as i keep the installation path etc seperate. my understanding is that i want to alot 32max ram per ELK and thus more than 65GB ram
Hi @ssi,
it's definitely technically possible. The recommended max heap of ~32GB is per java process.
I have machines with 256GB RAM that run 5 x ES, 1 x LS and 1 x Kibana and I leave about 50% of RAM to Lucene.
Cheers,
AB
P.S. now when I know Elastic Stack better I would rather have dedicated machines at least for Elasticsearch but I have to work with what was given to me :smiley:
ok thanks
consider this one solved!
FYI we’ve renamed ELK to the Elastic Stack, otherwise Beats and APM feel left out! :wink: Check out https://www.elastic.co/elk-stack
I know but ive Been with it since 2015 so itll be ELK to me :slight_smile: love your produkt please make the stuff i xpack awailable seperately i just need tge Security features as an example with AD integration no one did an open source version of that right ?
