My 5.6 Index is not being read in Kibana 6.0
Hi, I just updated Elastic Stack to 6.0 from 5.6 version. I had an index created in the previous major version, and in order to visualize it on Kibana 6.0, I had first to change the path.data in elasticsearch.yml.
I can do everything I want in my index through Console in Kibana, but it is not possible to create an Index Pattern based on it. Kibana can identify the index, but when I click in Create Button, nothing happens.
Do I need to do some extra thing in order to be able to work with this index in Kibana 6.0? I couldn't find any page in the internet that could help me on that!
Thanks,
Daniel
Did you follow the instructions mentioned here? https://www.elastic.co/guide/en/elasticsearch/reference/6.x/reindex-upgrade.html#reindex-upgrade
Can you please attach the logs as well?
Rashmi
I read somewhere that Elastic 6.0 could read indices from elastic 5.6. So I decided to upgrade, but after doing so, I found this article for reindexing. So I didn't reindex before upgrading.
Is is possible to do so running 6.0 version?
Thanks,
Daniel
HI
yes , its possible: instructions are here:
https://www.elastic.co/guide/en/kibana/current/migrating-6.0-index.html
Let us know if you need more help...
Rashmi
Hi Rashmi,
It worked pretty well!
Thanks again,
Daniel
Thanks for closing the loop, Daniel. Glad it worked!
-Rashmi
