Oscar73
(Óscar Gómez Fernández)
June 6, 2019, 10:43am
1
Hi, I'm trying to import a CSV file into my Kibana (6.7.2) using the Data Visualizer tool inside the Machine Learning tab, under a index pattern already created.
But when it comes to see its content, I have two problems:
I don't see anything in Discover
I get an error in all my visualizations (by the date format)
This is my date mapping when importing the CSV in the Data Visualizer
"Fecha de notificación": {
"type": "date",
"format": "dd/MM/YYYY HH:mm:ss",
"ignore_malformed": true
"Fina Afectación": {
"type": "date",
"Finalización prevista": {
"type": "date",
"Finalización real": {
"type": "date",
Can somebody help me, please?
What does your CSV look like? It would seem that the answer is right in the error message:
failed to parse date field [2018-04-01] with format [dd/MM/YYYY HH:mm:ss]
that date format doesn't look like the date field value.
You can see from the docs: https://www.elastic.co/guide/en/elasticsearch/reference/current/ml-find-file-structure.html that it will automatically properly guess the following date formats:
dd/MMM/YYYY:HH:mm:ss Z
EEE MMM dd HH:mm zzz YYYY
EEE MMM dd HH:mm:ss YYYY
EEE MMM dd HH:mm:ss zzz YYYY
EEE MMM dd YYYY HH:mm zzz
EEE MMM dd YYYY HH:mm:ss zzz
EEE, dd MMM YYYY HH:mm Z
EEE, dd MMM YYYY HH:mm ZZ
EEE, dd MMM YYYY HH:mm:ss Z
EEE, dd MMM YYYY HH:mm:ss ZZ
ISO8601
MMM d HH:mm:ss
MMM d HH:mm:ss,SSS
MMM d YYYY HH:mm:ss
MMM dd HH:mm:ss
MMM dd HH:mm:ss,SSS
MMM dd, YYYY h:mm:ss a
TAI64N
UNIX
UNIX_MS
YYYY-MM-dd HH:mm:ss
YYYY-MM-dd HH:mm:ss,SSS
YYYY-MM-dd HH:mm:ss,SSS Z
YYYY-MM-dd HH:mm:ss,SSSZ
YYYY-MM-dd HH:mm:ss,SSSZZ
YYYY-MM-dd HH:mm:ssZ
YYYY-MM-dd HH:mm:ssZZ
YYYYMMddHHmmss
If your CSV used one of those formats, you wouldn't have worry about anything - the tool would properly recognize the date pattern in your CSV and everything would work
Oscar73
June 7, 2019, 5:59am
3
Hi, thanks for the answer, dates on my CSV looks like this:
Josh1
(Josh )
June 7, 2019, 10:09am
4
The dates typically need to look something like this:
2019-06-05T03:22:05
Year-month-dayT time
Again:
You can modify your CSV to conform to one of the above formats and it will be imported without issue.
Oscar73
June 13, 2019, 8:43am
6
The solution was deleting the @timestamp field in the "Mappings" of the "Data Visualizer" when you import a CSV.
Ok, but now you've essentially made your data have no time element. Is that what you really wanted?
