but it's fake data
its not my server data
As you were entering some example data I thought you were looking to try Kibana.
If you are looking to onboard real data, have a look at the following resources instead:
https://www.elastic.co/webinars/introduction-elk-stack
https://www.elastic.co/webinars/using-the-elastic-stack-for-sensor-data-telemetry-and-metrics
https://www.elastic.co/webinars/integrating-data-stores-with-elasticsearch
hi dear i want it to work
and i inserted this field
I am not sure I understand what you are doing or looking to achieve.
If you want to explore how to work with kibana, use one of the sample data sets instead of creating this type of simple test data (which will not work with any ready-made dashboards as it does not have the correct structure). You can then look at how the data is structured in the Discover app and create and add new visualizations based on this data, which will teach you how to work with Kibana.
If you on the other hand are looking to analyse real data, follow the guides I liked to and get some real data into the cluster, e.g. using Filebeat modules. This inserts real data in the correct format and will work with the out-of-the-box visualisations.
i want to show geo point into map
and why always when i make visualize to any data show to me this
No Compatible Fields: The "blogs*" index pattern does not contain any of the following field types: (field type)
If you want to visualize your own sample data you need to make sure it has the appropriate mappings, which are often implemented through an index template. Once you have indexed some data with the correct mapping, you can start exploring your data in Kibana.
