Overall Min with metric Filter Ratio not showing results on Metric TSVB
Hi Team,
I'm trying to create a metric in TSVB.
First, I'm choosing a filter ratio to divide two counts. It's working fine until here.
Then, I choose an Overall Min with the metric Filter Ratio, here is when the problem begins. If I'm using a TSVB visualization, it shows the result, but if I choose Metric, it doesn't show a result at all. It says " The request for this panel failed all shards failed".
Please, could you help me?
Thanks!
I am trying to reproduce it with a sample data and it works fine for me. What Kibana version are you using? Is this the equivalent of your visualization?
