Hi there guys,
I'm new to ELK stack, I was able to install ELK, I can see some dashbords, topbeat for example, I can discover over filebeat index also but no luck with packet beat, this is what I've got.
curl 'localhost:9200/_cat/indices?v'
health status index pri rep docs.count docs.deleted store.size pri.store.size
yellow open %{[@metadata][logstash]}-2016.10.03 5 1 341 0 357.9kb 357.9kb
yellow open filebeat-2016.04.16 5 1 5858 0 2.2mb 2.2mb
yellow open %{[@metadata][logstash]}-2016.10.02 5 1 202 0 267.9kb 267.9kb
yellow open %{[@metadata][logstash]}-2016.10.04 5 1 50744 0 25mb 25mb
yellow open topbeat-2016.09.23 5 1 611555 0 165.6mb 165.6mb
yellow open %{[@metadata][sensu]}-2016.10.04 5 1 35780 0 14.8mb 14.8mb
yellow open filebeat-2016.09.21 5 1 111446 0 42.5mb 42.5mb
yellow open %{[@metadata][beat]}-2016.10.03 5 1 56 0 152.8kb 152.8kb
yellow open filebeat-2016.09.22 5 1 121336 0 46.1mb 46.1mb
yellow open filebeat-2016.09.20 5 1 93355 0 33.7mb 33.7mb
yellow open filebeat-2016.10.02 5 1 202 0 172.8kb 172.8kb
yellow open filebeat-2016.10.04 5 1 12527 0 9.3mb 9.3mb
yellow open topbeat-2016.10.04 5 1 38219 0 13.8mb 13.8mb
yellow open filebeat-2016.10.03 5 1 341 0 250.3kb 250.3kb
yellow open %{[@metadata][beat]}-2016.09.16 5 1 22 0 181.7kb 181.7kb
yellow open filebeat-2016.09.11 5 1 200 0 274.5kb 274.5kb
yellow open filebeat-2016.09.12 5 1 2302 0 1.8mb 1.8mb
yellow open filebeat-2016.09.13 5 1 3349 0 2.7mb 2.7mb
yellow open .kibana 1 1 106 0 91.5kb 91.5kb
yellow open filebeat-2016.09.18 5 1 68771 0 23.3mb 23.3mb
yellow open filebeat-2016.09.19 5 1 74057 0 26.1mb 26.1mb
yellow open filebeat-2016.08.11 5 1 13 0 75.4kb 75.4kb
yellow open filebeat-2016.09.14 5 1 3568 0 3.1mb 3.1mb
yellow open filebeat-2016.09.15 5 1 948288 0 168mb 168mb
yellow open filebeat-2016.09.16 5 1 50915 0 15.2mb 15.2mb
yellow open filebeat-2016.09.17 5 1 63702 0 20.1mb 20.1mb
Packetbeat client configuration:
grep -v '#' packetbeat.yml
interfaces:
device: any
protocols:
http:
ports: [80]
procs:
enabled: false
monitored:
- process: sshd
cmdline_grep: sshd
output:
logstash:
hosts: ["server:5044"]
index: packetbeat
tls:
certificate_authorities: ["/etc/pki/tls/certs/logstash-forwarder.crt"]
file:
path: "/var/log/packetbeat"
filename: packetbeat.log
number_of_files: 60
shipper:
tags: ["server-test"]
ignore_outgoing: true
refresh_topology_freq: 60
topology_expire: 120
queue_size: 1000
geoip:
paths:
- "/usr/share/GeoIP/GeoLiteCity.dat"
logging:
to_syslog: true
to_files: true
files:
path: /var/log/packetbeat
keepfiles: 60
level: debug
NOTE: ( cert is working, I'm using it with filebeat and topbeat )
Under kibana when I select the index I've get this message:
Mapping conflict! A field is defined as several types
(string, integer, etc) across the indices that match this pattern. You
may still be able to use these conflict fields in parts of Kibana, but
they will be unavailable for functions that require Kibana to know their
type. Correcting this issue will require reindexing your data.
On the server side:
curl -XGET 'http://localhost:9200/packetbeat-*/_search?pretty'
"took" : 1,
"timed_out" : false,
"_shards" : {
"total" : 0,
"successful" : 0,
"failed" : 0
"hits" : {
"total" : 0,
"max_score" : 0.0,
"hits" : [ ]
Software version:
kibana-4.4.2-1.x86_64
elasticsearch-2.4.0-1.noarch
packetbeat-1.3.1-1.x86_64
Red Hat Enterprise Linux Server release 6.7 (Santiago)
Any help appreciated
Best regards
