Per index path.data setting possible?
Is it possible to set path.data per index? We would like to store one
index on a dedicated SSD while other indexes will be stored on slower HDDs.
/Niklas
No, its not possible, though it makes sense. Shouldn't be too difficult to
add, just requires thinking on how to expose it.
On Wed, Jun 13, 2012 at 11:23 AM, Niklas Therning niklas@therning.orgwrote:
/Niklas
Also, open an issue?
/Niklas
One more thing, you can have SSDs on some machines, and disks on others,
and have the index allocation set to put indices that need SSDs on one set
of machines, and the ones with disk on the others.
to add, just requires thinking on how to expose it.
/Niklas
Issue created here:
I just discovered the shard allocation stuff and will look into how we
can use it. Thanks!
/Niklas
others, and have the index allocation set to put indices that need
SSDs on one set of machines, and the ones with disk on the others.
On Thu, Jun 14, 2012 at 11:09 PM, Shay Banon <kimchy@gmail.com
    difficult to add, just requires thinking on how to expose it.
    <niklas@therning.org <mailto:niklas@therning.org>> wrote:
        to store one index on a dedicated SSD while other indexes
        /Niklas
This would become a very nice feature. One more thing I should add to this
is the ability to move an existing index from SSD to a HDD when we feel
that the current index is no longer the most searched index. For example,
News articles, our application indexes hundreds of millions of news
articles and we create index per day. Everyday, the index would become 20
GB in size. Wr would like to have the first 10 days' index in SSD and the
others in HDDs so that the search will be pretty fast in the default
stories section and then move the last days index to HDD when we create a
new index. So, basically, if there is a mechanism to move an index from SSD
to HDD, that would be very helpful. Not a reasonable request?
Regards,
Kavin
On Fri, Jun 15, 2012 at 1:48 PM, Niklas Therning niklas@therning.orgwrote:
Issue created here:
Add per index path.data setting · Issue #2025 · elastic/elasticsearch · GitHub
I just discovered the shard allocation stuff and will look into how we can
use it. Thanks!
/Niklas
/Niklas
Oops, sorry I think Niklas already added this to his request. Good one.
Thanks!
Kavin
Regards,
Kavin
Issue created here:
can use it. Thanks!
/Niklas
/Niklas
