Problem with index-pattern id when recreating index
After recreating index stats-* all the saved objects (visualizations, dashboards,...) are failing to load with error:
Could not locate that index-pattern (id: 70ea4880-815b-11e9-a33a-156632c3253a), click here to re-create it
When I check with query:
POST .kibana/_search
"term": {
"type": {
"value": "index-pattern"
"took" : 0,
"timed_out" : false,
"_shards" : {
"total" : 1,
"successful" : 1,
"skipped" : 0,
"failed" : 0
"hits" : {
"total" : 1,
"max_score" : 2.9123507,
"hits" : [
"_index" : ".kibana_1",
"_type" : "doc",
"_id" : "index-pattern:853edd20-a8b4-11e9-85c3-6d5ebd116eca",
"_score" : 2.9123507,
looks like index-pattern has changed
for
...but why? how can I fix it?
If I go to Saved Objects and change the pattern-id manually the visualization gets fixed, should I go manually to each saved object and change the pattern-id??
Thank you for your help,
Juanjo.
When creating an index pattern there is an option under the "Advanced" tab that allows you to specify the ID. There you could specify the ID that it had before: 70ea4880-815b-11e9-a33a-156632c3253a
Thank you Marius.
