Problem with TTL
I'm trying to set TTL on a document as following:
  1. Create a new document:
    curl "http://MYHOST:9200/deni_index/deni_type/1?pretty=true" -d
    '{"comment":"test"}'
The "_ttl" : { "enabled" : true } is missing. If I set a default value:
*curl http://MYHOST:9200/deni_index/deni_type/_mapping?pretty=true -d
'{"deni_type" : { "_ttl" : { "enabled" : true, "default":"30000" }}}'
If I add new documents with TTL (curl
"http://MYHOST:9200/deni_index/deni_type/2?ttl=30000) the document don't
expired after 30 sec.
Could you please tell me what I'm doing wrong?
The version of the elastic search is 0.20.4. The documentation I read is:
http://www.elasticsearch.org/guide/reference/mapping/ttl-field.html
Regards, Denitsa
It's possible to enable TTL only during mapping creation. After mapping is
created, you can only change the default value. In your case, you create
mappings first (by indexing the document) and only then try enable TTL.
That's not supported at the moment.
On Wednesday, February 27, 2013 7:55:24 AM UTC-5, Denica Gencheva wrote:
If I add new documents with TTL (curl "
The version of the Elasticsearch is 0.20.4. The documentation I read is:
Elasticsearch Platform — Find real-time answers at scale | Elastic
Regards, Denitsa
I'm curious if that functionality is going to be added. (ability to add
ttl to an existing mapping)
So, for now one should create a new index with TTL enabled and copy the old
index to it, right?
is: Elasticsearch Platform — Find real-time answers at scale | Elastic
Regards, Denitsa
