Problems with homebrew installation
I tried to follow the basic instructions here: Install Elasticsearch on macOS with Homebrew | Elasticsearch Guide [7.17] | Elastic but they don't work
brew tap elastic/tap - works fine
but
brew install elastic/tap/elasticsearch-full results in:
Error: elastic/tap/elasticsearch-full: Calling plist_options is disabled! Use service.require_root instead.
Please report this issue to the elastic/tap tap (not Homebrew/brew or Homebrew/homebrew-core), or even better, submit a PR to fix it:
/opt/homebrew/Library/Taps/elastic/homebrew-tap/Formula/elasticsearch-full.rb:68
Are there any workarounds for this until it gets fixed?
Hi @dpa Welcome to the community.
I love brew for Mac.
I do not know the issue for this
But Personally I think the tar.gz is a better way to install on the Mac.
It seems more "contained" and easy to manage.
Also I use docker extensively on Mac to setup and tear down elasticsearch components
I know that does not actually answer your question but just some thoughts from someone that uses elasticsearch extensively on a Mac
even i am facing the same issue,
Error: elasticsearch-full: Calling plist_options is disabled! Use service.require_root instead.
/usr/local/Homebrew/Library/Taps/elastic/homebrew-tap/Formula/elasticsearch-full.rb:68
