Python Elasticsearch : Index mapping inconsistencies between 'es.index' and 'es.indices.create'
I'm trying to implement a custom index mapping (my_mapping) in Python, BUT, I do not get the expected index mapping after the python file is run!
file.py
my_mapping = """
    "settings": {
        "number_of_shards": "1",
        "number_of_replicas": "1"
    "mappings": {
        "properties": {
            "site": {
                "type": "completion",
            "geometry": {
                "type": "geo_shape"
result = es.index(index='my_index', document=my_mapping)
Expected Output:
  "mappings": {
    "_doc": {
      "properties": {
        "geometry": {
          "type": "geo_shape"
        "site": {
          "analyzer": "simple",
          "preserve_separators": true,
          "preserve_position_increments": true,
          "max_input_length": 200
Actual horrible output:
  "mappings": {
    "_doc": {
      "properties": {
        "mappings": {
          "properties": {
            "properties": {
              "properties": {
                "geometry": { ...........
BUT! NOTE that when I instead use the following python to create the index, I DO get the expected outcome.
result = es.indices.create(index='my_index', document=my_mapping)
Can someone please explain to me the inconsistency, and HOW to generate the expected outcome USING es.index
I think that es.index is meant to index documents. Not to call the create index API.
@dadoonet is correct
es.indices.create - API Documentation — Elasticsearch 7.15.1 documentation
es.index - API Documentation — Elasticsearch 7.15.1 documentation
Thanks all for clarifying. I’ll stick to using es.indices.create
@warkolm - I forgot to mention but I also get a depreciation warning when using es.indices.create()
I’m not sure of how to rectify this
Ahh not sure on that, hopefully one of the clients team will drop by and comment :slight_smile:
@warkolm I can answer my own question now. To circumvent the deprecation warning I use the explicit "mappings" parameter as opposed to the more generic "body" parameter. Eg:
es.indices.create(index='my_index', mappings="my_mapping")
No more warnings!
