Records not showing when filter using scripted field in kibana control
I have created a kibana control which is loading the records from _source and also created scripted field. Now this main control is a parent to scripted field control.
On selection main field control option it loads appropriate data in scripted field control.
Now based on the scripted field selection I need to filter and show records in kibana saved search in kibana dashboard. But it is not showing any records in dashboard.
Any idea?
Thanks in advance
It sounds like your script or the filter based on the script is not matching any documents- but it's not possible to know based on the details in your original question. Does it work when you use the same filter in the Discover app?
