Shrinked index should have same security settings than original index
When using ILM to reduce index, the new index change its name: "shrink-zda-original".
When using security, we configure some permissions to "original" index.
ILM will break permissions, this is really annoying using elastic-hadoop library because the lib uses the index behind the alias, hence give security errors.
As a dirty workaround, I see also permissions against:
  indices:
  - names:
    - events
    - "events-*"
    - "shrink-*-events-*"
    privileges:
    - read
