Split Index Help Required
I am trying to reindex my index with following commands. And I get an error.
source - transactions-reindexed-2018.12.03-01
PUT t2
    "settings": {
        "index.number_of_shards" : 5,
        "index.number_of_routing_shards" : 100
PUT /transactions-reindexed-2018.12.03-01/_settings
  "settings": {
    "index.blocks.write": true
POST transactions-reindexed-2018.12.03-01/_split/t2
  "settings": {
    "index.number_of_shards": 10
Error
      "error": {
        "root_cause": [
            "type": "illegal_state_exception",
            "reason": "the number of routing shards [5] must be a multiple of the target shards [10]"
      "status": 500
Index Info
Health:
green
Status:
open
Primaries:
5
Replicas:
1
Docs Count:
54350414
Docs Deleted:
0
Storage Size:
4gb
Primary Storage Size:
2gb
It looks like you have mixed up the source and destination indices. I believe it should look like this:
PUT t2
  "settings": {
PUT /t2/_settings
  "settings": {
POST t2/_split/transactions-reindexed-2018.12.03-01
  "settings": {
Thanx Christian,
When I ran as you instructed, got following error,
  "error": {
    "root_cause": [
        "type": "resource_already_exists_exception",
        "reason": "index [transactions-reindexed-2018.12.03-01/cNqlGSmwTt-pa_LYvkGyeQ] already exists",
        "index_uuid": "cNqlGSmwTt-pa_LYvkGyeQ",
        "index": "transactions-reindexed-2018.12.03-01"
  "status": 400
I think that error message is quite clear. You can not create the new index as it already exists.
i wanna split my "transactions-reindexed-2018.12.03-01" index with 5 shards to 10 shards.
I don't have an index named t2 till I create using the 1 step of the split command.
What I am doing wrong here?
The index you want to split (t2 in the example) must have been created with index.number_of_routing_shards set. If you are looking to split transactions-reindexed-2018.12.03-01 into a new index named t2 you will need to swap the index names in the example I provided. If the index you want to split was not created with the index.number_of_routing_shards parameter, split will not work and you instead need to reindex.
It looks like this is an hourly index. How much data does it contain as you are considering a split? Keep in mind that having lots of small indices and shards can be very inefficient and affect performance.
