Strange problem with a boolean field
has anyone had a problem with a boolean field having a value 't' when
normally it is 'T' or 'F' (for true and false)? It's happens to me
occasionally in my integration tests. I've tried to simplify the problem
into a gist, but annoyingly it doesn't happen when I do that... grr.
A screenshot of the problem:-
https://docs.google.com/open?id=0B3kE2Ho2wIf5ZjltNjJKNEJ2cG8
here's roughly what happens as a gist:-
(but that actually works for me)
Any ideas?
Hi!
On 11.12.2012, at 02:35, Ian Clark wrote:
has anyone had a problem with a boolean field having a value 't' when normally it is 'T' or 'F' (for true and false)? It's happens to me occasionally in my integration tests. I've tried to simplify the problem into a gist, but annoyingly it doesn't happen when I do that... grr.
You've come across this: Facet value of boolean mapped fields should be "true" or "false" · Issue #2462 · elastic/elasticsearch · GitHub
Boolean values are stored as 'T' and 'F' in the index, but aren't properly converted back to 'true' and 'false' when being returned to a client.
There's a workaround and a patch, but I guess it will take a little while to get it in a release.
cheers,
-k
Where does my little 't' value come from? It is a problem for me in that:-
I then filter on true, and get back all results minus the little 't'
document:-
like so:- failing-filter.json · GitHub
IC
On Tue, Dec 11, 2012 at 10:15 AM, Kay Röpke kroepke@gmail.com wrote:
Hi!
cheers,
-k
I tried it with 0.20.1 and I cannot reproduce it. Which version of es and
java are you using? Is it reproducible on a fresh install of elasticsearch?
All I am getting is
"facets" : {
"verified_terms" : {
"_type" : "terms",
"missing" : 0,
"total" : 30,
"other" : 0,
"terms" : [ {
"term" : "T",
"count" : 30
document:-
IC
On Tue, Dec 11, 2012 at 10:15 AM, Kay Röpke <kro...@gmail.com<javascript:>
wrote:
Hi!
client.
cheers,
-k
I was using a snapshot when I ran it manually and 0.20.1 in my integration
test, having sorted that out I can now reproduce the problem with this
simpler script:-
My java version is 1.7u9. Do this fail for you?
thanks for looking.
All I am getting is
"facets" : {
"_type" : "terms",
"missing" : 0,
"total" : 30,
"other" : 0,
"terms" : [ {
"term" : "T",
"count" : 30
that:- I then filter on true, and get back all results minus the little 't'
document:-
like so:- https://gist.github.com/**26a7f43bcbbfbff836a6https://gist.github.com/26a7f43bcbbfbff836a6
IC
On Tue, Dec 11, 2012 at 10:15 AM, Kay Röpke kro...@gmail.com wrote:
Hi!
You've come across this: https://github.com/**
elasticsearch/elasticsearch/**issues/2462https://github.com/elasticsearch/elasticsearch/issues/2462
client.
cheers,
-k
Ian,
Thank you for reporting the bug. We are looking into it. As a work around,
you can fix your mapping by moving the "mappings" element to the same level
as "settings":
curl -XPUT 'http://localhost:9200/booltest/' -d '
"settings": {
"index": {
"number_of_shards": 1,
"number_of_replicas": 0
"mappings": {
"thing": {
"properties": {
"flag": { "type" : "boolean" }
"_all": {
"enabled": "false"
Igor
On Friday, December 14, 2012 4:10:21 AM UTC-8, Ian Clark wrote:
simpler script:-
problem with boolean fields · GitHub
thanks for looking.
On Thu, Dec 13, 2012 at 9:32 PM, Igor Motov <imo...@gmail.com<javascript:>
All I am getting is
"facets" : {
"_type" : "terms",
"missing" : 0,
"total" : 30,
"other" : 0,
"terms" : [ {
"term" : "T",
"count" : 30
document:-
IC
Hi!
client.
cheers,
-k
Igor,
I totally missed that, so it was falling back to a dynamic mapping and that
is the problem?
Thanks for looking and the work around.
Ian
On Fri, Dec 14, 2012 at 5:26 PM, Igor Motov imotov@gmail.com wrote:
Ian,
as "settings":
"settings": {
"index": {
"mappings": {
"thing": {
"properties": {
"_all": {
"enabled": "false"
Igor
integration test, having sorted that out I can now reproduce the problem
with this simpler script:-
https://gist.github.com/**4284891 https://gist.github.com/4284891
thanks for looking.
and java are you using? Is it reproducible on a fresh install of
elasticsearch? All I am getting is
"facets" : {
"_type" : "terms",
"missing" : 0,
"total" : 30,
"other" : 0,
"terms" : [ {
"term" : "T",
"count" : 30
document:-
like so:- https://gist.github.com/**2**6a7f43bcbbfbff836a6https://gist.github.com/26a7f43bcbbfbff836a6
IC
Hi!
You've come across this: https://github.com/**elast**
icsearch/elasticsearch/**issues/**2462https://github.com/elasticsearch/elasticsearch/issues/2462
client.
cheers,
-k
Yes, in your example it's effectively using dynamic mapping.
On Friday, December 14, 2012 9:55:56 AM UTC-8, Ian Clark wrote:
Igor,
that is the problem?
Ian
On Fri, Dec 14, 2012 at 5:26 PM, Igor Motov <imo...@gmail.com<javascript:>
wrote:
Ian,
around, you can fix your mapping by moving the "mappings" element to the
same level as "settings":
"settings": {
"index": {
"mappings": {
"thing": {
"properties": {
"_all": {
"enabled": "false"
Igor
thanks for looking.
"facets" : {
"_type" : "terms",
"missing" : 0,
"total" : 30,
"other" : 0,
"terms" : [ {
"term" : "T",
"count" : 30
document:-
IC
Hi!
client.
cheers,
-k
