erikg
January 8, 2025, 9:12pm
1
I want to create a text panel where I can add links to the right and wording on the left.
This is what I am trying to do:
Like the image above, I want to say something like "Welcome to Elastic" and the left of the same line , add some links.
stephenb
(Stephen Brown)
January 9, 2025, 5:25am
2
Don't think you are going to be able to do that with TSVB / Markdown.
HTML supports that simple markdown does not as far as I know... probable need to create 2 panels
Hi, you can try to use Custom CSS : TSVB Visualization>Markdown>Panel options>Style>Custom CSS
I managed to make a responsive menu like this :
This combines markdown and css, maybe you'll be able to do what you want!
erikg
January 9, 2025, 2:40pm
4
Hey @GinkoLucas ,
would mind sharing the css you wrote to create this?
Thanks man!
Markdown :
- [Menu](https://www.google.com/)
- Click here
- [First link](https://www.google.com/)
- [Second link](https://www.google.com/)
- Previous
- [Yes](https://www.google.com/)
- [No](https://www.google.com/)
Css :
ul, li {
margin:0; padding:0; list-style: none; position: relative;
li:hover {
cursor:pointer;
a {
text-decoration:none;
ul li:nth-child(3n) {
background-color: #017f75;
ul li:nth-child(3n+1) {
background-color: #45a29a;
ul li:nth-child(3n+2) {
background-color: #73b9b3;
/* Level 1 */
ul {
display: inline-flex; flex-wrap: wrap;
ul li {
display: inline-flex; padding: 0 1rem 0 1rem; text-align:left; margin-right: 0.1rem; color: #FFFFFF; height: 4rem; align-items: center;
ul li:hover {
transition: all 0.3s ease-out; background-color: #0d5147; color: #c9f95a;
/* Level 2 */
ul ul {
display: none;
ul ul li {
display: flex; white-space: nowrap; height: 4rem; align-items: center;
ul li:hover > ul {
display: flex; position: absolute; top: 4rem; left: 0;
It's not perfect, but I imagine you're going to improve it.
stephenb
(Stephen Brown)
January 9, 2025, 3:41pm
6
Wow @GinkoLucas I didn't even know you could do that!!! Today I Learned
