WHERE clause does not work for Kibana INDECES
Hello all,
I have tried to execute below query to return all indexed documents where type = dashboard. Idea is to grab all dashboard objects and do some visualization in canvas.
POST _xpack/sql?format=txt
"query": "SELECT * FROM .kibana_1 WHERE type = dashboard"
returns:
Failed to connect to Console's backend.
Please check the Kibana server is up and running
    "query" : "SELECT * FROM \".kibana_1\" WHERE type = 'dashboard'"
You'd probably get:
    "error": {
        "root_cause": [
                "reason": "Trying to retrieve too many docvalue_fields. Must be less than or equal to: [100] but was [269]. This limit can be set by changing the [index.max_docvalue_fields_search] index level setting."
So you'd need to SELECT the fields you need instead of *.
This worked! thank you :-)))
You're welcome!
