New ELK 6.2.3 installation on Windows. I installed WLB on a Windows 2012R2 server and specified in the yml to setup dashboard. The index pattern and dashboard are there but I am getting the following error:
This can be caused by not having data in your winlogbeat indexes, please check that you have any data in the winlogbeat-* indexes in Elasticsearch.
If you have, or you are not sure, you can also try to reload the index field list.
