[6.1] Submitting index-pattern and visualizations to ".kibana" index
I'm upgrading from ES and Kibana 2.3 to 6.1, and can't seem to submit index-pattern, visualizations, dashboard etc to the ".kibana" index.
This is how i was submitting them in ES 2.3
curl -vvv -H "Content-Type: application/json" -XPUT -d@/kibana-objects/index-pattern/logs-\*.json "elasticsearch:9200/.kibana/index-pattern/logs-*?pretty
Same for visualizations and dashboard.
Now in 6.1, when I try to do this I get this response:
  "error" : {
    "root_cause" : [
        "type" : "illegal_argument_exception",
        "reason" : "Rejecting mapping update to [.kibana] as the final mapping would have more than 1 type: [index-pattern, doc]"
  "status" : 400
How can i submit default index pattern for kibana in 6.1 ?
Hi Hazim,
We have removed types from 6.0. You need to upgrade to 5.6 first - migrate your .kibana index and then upgrade to 6.1.
Here are our doc links:
Upgrading elasticsearch
https://www.elastic.co/guide/en/elasticsearch/reference/current/setup-upgrade.html
Upgrading kibana
https://www.elastic.co/guide/en/kibana/current/upgrade.html
Here is a blogpost for explaining Kibana's upgrade to 6.0:
Here is a webinar:
https://www.elastic.co/webinars/upgrading-your-elastic-stack
Hope this helps.
Thanks,
Bhavya
Im doing a clean setup just wanted to use my old files i.e. index patterns visualizations etc. or wanted to convert them to 6.1 format.
Would i still need to upgrade to 5.6 first?
Yep :slight_smile: 5.6 is mandatory to upgrade to 6.x.
Cheers,
Bhavya
