Hey dadoonet,
Thanks for the reply! I'm glad this was helpful to you.
For me, I was able to get past the error that I original posted about,
but then got stuck during ./gradlew test because of a
"java.lang.ClassNotFoundException: junit.framework.TestCase" during
the ":plugins-lang-groovy:compileTestGroovy" phase.
One thing that's greatly complicating all of this for me is that I'm
working from China, and the Great Firewall fo China is incredible in
its breadth: random sites just don't work, or are so slow they just
time out. For example, I can't access jboss.org.
I'll keep trying, and will update if I make any progress. For
reference, the following is the error that I get from ./gradlew test.
[ant:groovyc] >>> a serious error occurred: junit/framework/TestCase
[ant:groovyc] >>> stacktrace:
[ant:groovyc] java.lang.NoClassDefFoundError: junit/framework/TestCase
[ant:groovyc] at java.lang.ClassLoader.defineClass1(Native Method)
[ant:groovyc] at
java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
[ant:groovyc] at java.lang.ClassLoader.defineClass(ClassLoader.java:
615)
[ant:groovyc] at
java.security.SecureClassLoader.defineClass(SecureClassLoader.java:
141)
[ant:groovyc] at
java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
[ant:groovyc] at java.net.URLClassLoader.access
$000(URLClassLoader.java:58)
[ant:groovyc] at java.net.URLClassLoader$1.run(URLClassLoader.java:
197)
[ant:groovyc] at java.security.AccessController.doPrivileged(Native
Method)
[ant:groovyc] at
java.net.URLClassLoader.findClass(URLClassLoader.java:190)
[ant:groovyc] at java.lang.ClassLoader.loadClass(ClassLoader.java:
306)
[ant:groovyc] at sun.misc.Launcher
$AppClassLoader.loadClass(Launcher.java:301)
295)
[ant:groovyc] at
groovy.lang.GroovyClassLoader.loadClass(GroovyClassLoader.java:696)
[ant:groovyc] at
groovy.lang.GroovyClassLoader.loadClass(GroovyClassLoader.java:564)
[ant:groovyc] at
org.codehaus.groovy.control.ResolveVisitor.resolveToClass(ResolveVisitor.java:
709)
[ant:groovyc] at
org.codehaus.groovy.control.ResolveVisitor.resolve(ResolveVisitor.java:
275)
[ant:groovyc] at
org.codehaus.groovy.control.ResolveVisitor.resolveFromDefaultImports(ResolveVisitor.java:
466)
[ant:groovyc] at
275)
[ant:groovyc] at
243)
[ant:groovyc] at
org.codehaus.groovy.control.ResolveVisitor.resolveOrFail(ResolveVisitor.java:
227)
[ant:groovyc] at
239)
[ant:groovyc] at
235)
[ant:groovyc] at
org.codehaus.groovy.control.ResolveVisitor.visitClass(ResolveVisitor.java:
1271)
[ant:groovyc] at
org.codehaus.groovy.control.ResolveVisitor.startResolving(ResolveVisitor.java:
148)
[ant:groovyc] at org.codehaus.groovy.control.CompilationUnit
$8.call(CompilationUnit.java:601)
[ant:groovyc] at
org.codehaus.groovy.control.CompilationUnit.applyToSourceUnits(CompilationUnit.java:
839)
[ant:groovyc] at
org.codehaus.groovy.control.CompilationUnit.doPhaseOperation(CompilationUnit.java:
544)
[ant:groovyc] at
org.codehaus.groovy.control.CompilationUnit.compile(CompilationUnit.java:
493)
[ant:groovyc] at
476)
[ant:groovyc] at
org.codehaus.groovy.tools.FileSystemCompiler.compile(FileSystemCompiler.java:
67)
[ant:groovyc] at
org.codehaus.groovy.tools.FileSystemCompiler.doCompilation(FileSystemCompiler.java:
180)
[ant:groovyc] at
org.codehaus.groovy.tools.FileSystemCompiler.commandLineCompile(FileSystemCompiler.java:
148)
[ant:groovyc] at
org.codehaus.groovy.tools.FileSystemCompiler.main(FileSystemCompiler.java:
162)
[ant:groovyc] Caused by: java.lang.ClassNotFoundException:
202)
Method)
[ant:groovyc] at
306)
247)
[ant:groovyc] ... 33 more
FAILURE: Build failed with an exception.
- What went wrong:
Execution failed for task ':plugins-lang-groovy:compileTestGroovy'.
Cause: Forked groovyc returned error code: 1
Cheers!
Matt
On Aug 18, 7:24 pm, dadoonet da...@pilato.fr wrote:
Matt wrote:
$> gradle eclipse
Thanks Matt for this command. I didn't know how to import my project into
eclipse and actually it's quite simple... You save my day !
BTW, everything is working fine in compiling with gradle, gradle test and
gradle eclipse when I have a direct internet access. (at home)
When I'm behind a proxy (at work), I can not download all jars. Some works.
Some others don't !
Although I set up my JAVA_OPTS with the right proxy, it still not work.
Where:
Build file 'D:\Dev\elasticsearch\modules\jarjar\build.gradle' line: 38
What went wrong:
Execution failed for task ':jarjar:jar'.
Cause: Could not resolve all dependencies for configuration
':jarjar:runtime':
- unresolved dependency:
com.googlecode.concurrentlinkedhashmap#concurrentlinkedhashmap-lru;1.2: not
found
So perhaps you have the same problem on your side ?
View this message in context:http://elasticsearch-users.115913.n3.nabble.com/Anybody-else-having-p...
Sent from the Elasticsearch Users mailing list archive at Nabble.com.
