Elastic-agent with system module does not send any data to elasticsearch
Oh Yay.. we crossed in the Internet!!
Shoot always something simple AFTER you debug everything else!
Have a Happier Thanksgiving Now!
@zozo6015 Where did you overlook it... in case it helps others?
In the fleet settings the elasticsearch host was the default https://localhost:9200 I was so concentrating to get the fingerprint right that I have forget to change the elasticsearch address.
Ahh you mean in the kibana.yml I don't even remember when that gets setup.
Good I learn too! Thanks! I have a FQDN ... I think I would need that if it was not on the Same Subnet!
xpack.fleet.outputs: [{id: fleet-default-output, name: default, is_default: true, is_default_monitoring: true, type: elasticsearch, hosts: ['https://10.168.0.12:9200'], ca_trusted_fingerprint: sdfgsdfgsdfgdsfg4c00d5837a57ba07ea89756df453c42d1659442c1d7f192d}]
I mean in this dashboard.
Yeah I just saw that ... debugging so many things loosing track!
Cool!
Mine came from initial setup.. it is in my kibana.yml notice the Lock Icon.
If I take it out of the kibana.yml and add it in the way you did...
This is all good learnings... even we are still learning agent :slight_smile:
