Hi Team,
we are trying to hide the Help Icon from Kibana 8.5.3 on top right corner as below after we logged in.
Thanks.
Hi Team,
Thanks.
Hi @Abj_Ins,
I'm not aware of a setting in Kibana to hide the help icon specifically. So if you wanted to do that you would need to change the CSS or write a plugin similar to the approach in this thread.
Hope that helps!
Thanks for your response.
We followed below steps till 8.5.2 version... but in 8.5.3, we didn't find "header_help_menu_HeaderHelpMenu" in core.entry.js file.
Can anyone please help us on this.
Hi @Abj_Ins,
Having a dig around in ChromeDevTools, it looks like setting the visibility on path #globalHeaderBars > div.euiHeader.euiHeader--dark.euiHeader--fixed.header__firstBar > div:nth-child(3) > div:nth-child(3) if probably what you need:
