Issue when calculating MAX TPS using MAX Bucket Aggregation
I am trying to add a visualization to calculate MAX TPS for an API, attached the Visualization settings.
I am selecting the minimum interval in my date histogram as 1s, but the metric result I am getting is for 10m interval instead of 1s, could you please help us with the issue.
I am able to calculate AVG TPS using Avg_Bucket Metric type, but Max_bucket is not working as expected, am I missing anything here? Appreciate any help in this regard.
Kibana Version : 7.6.1
Elasticsearch Version: 7.6.1
I am expecting a value approximately 70, but am getting 1500, which is I am expecting the max bucket size of 10m bucket interval but not 1s buckets.
The time duration I am selecting is 1 hr, which is below my max_buckets parameter limit set in my Elasticsearch.
Cheers, Ravi.
@elastic_team, can some one take a look at it and help?
We want to see if this can be achieved with out increasing the bucket-size .
@Nathan_Reese , might be a simple solution, can you please suggest
My timestamp filed is just timestamp, and not @timestamp.
What is the time range? Kibana auto scales the range when too many buckets are created. You can increase the number of buckets by setting histogram:maxBars
Here is a screen shot from newer versions of kibana that make this more explicit in the UI
yes the timestamp field is just timestamp.
I am using smaller intervals only, like 30 mins, in such cases the bucket size should only 1800.
