Multi-tenancy problem with Kibana
Hello! This is my issue:
I try to setup a multi-tenancy system in my Kibana, describe as follow:
AS IS ENV
Index: twitter_index, .kibana
Dashboards: 1,2,3,4 (stored in .kibana)
TO BE ENV (I would like 2 different kibana users that will create different dashboards for future dashboards only users)
Index: twitter_index, .kibana, .kibana-2, .kibana-3
Custom roles definitions:
kibana_user_role_2 (Q: stored in .security-6?)
kibana_user_role_3 (Q: stored in .security-6?)
User definitions:
U: marco R: kibana_user_role_2
U: roberto R: kibana_user_role_3
Dashboards: 1,2 (stored in .kibana-2), 3,4 (stored in .kibana-3)
So here are the steps I followed:
  1. I created .kiban-a2 index with no mappings. Q: should I do it or kibana will create it automatically later?
  2. I logged as elastic (superuser) and created kibana_user_role_2 in this way (it’s like a default kibana_user but with different index privileges):
This is the output from security API:
"kibana_user_role_2" : {
"cluster" : [ ],
"indices" : [
    "names" : [
      ".kibana-2"
    "privileges" : [
      "manage",
      "read",
      "index",
      "delete"
    "field_security" : {
      "grant" : [ ]
"run_as" : [ ],
"metadata" : { },
"transient_metadata" : {
  "enabled" : true
What I expect now is that marco user will be able to create and store dashboards inside .kibana-2 index, but when I login I get the following message when opening Discover tab:
Config: Error 403 Forbidden: action [indices:data/write/update] is unauthorized for user [marco]: [security_exception] action [indices:data/write/update] is unauthorized for user [marco]
What am I missing?
Thanks!!
Hi there, could you please clarify what you'd like to achieve, just to help me understand better?
It sounds like you want to have three tenants: two tenants will create dashboards, and one tenant will only read them. Is this correct?
Thanks,
CJ
Hi! First of all thank you for the quick response :grinning:
My goal is to create dedicated dashboards for specific users. I give you an example; I have 3 users for my kibana: superuser , user A and user B. I need to create 2 different dashboards(dashboard A and dashboard B) as superuser(but it is not a necessary condition for superuser to create them) where the first one it's visible only from user A and the second only from user B. So if user A log in to Kibana, he will see only the the dashboard A (ditto for user B and dashboard B).
From what I have understood I need to create dedicated indices .kibana for every users, like .kibana_user_A and .kibana_user_ B, and load the dedicated dashboards t here( load dashboard A into .kibana_user_A and dashboard B in .kibana_user_B), but I don't know how to load the specific .kibana index for the specific user when I log in.
I know that exist a plug-in that do this but I'd like to know if exist a solution without proxy server and possibly for free :wink:
Thank You!
You will need multiple instances of Kibana to achieve this. Each instance will use one of those .kibana indices.
