Need help building dashboard
Hello, I want to build a dashboard that shows users with failed logins and the number of failed logins for the last 24 hours. I built a dashboard, but it shows all users, even those whose login did not fail. How do I limit it to only those users with failed logins? Thanks.
HI,
To limit the dashboard to only show users with failed logins, you need to apply a filter to your visualizations.
For example, filter on the field that represents the login status and enter the value that represents a failed login.
Regards
