We were able to setup a squid proxy to our Kibana 3 webserver, however we
want to setup a reverse proxy so that users won't have to manual input the
proxy information inside their web browser. The forward proxy worked fine,
however with the reverse proxy, when the page loads, it won't bring up any
data from the elasticsearch cluster. One of our analysts has determined the
json code is not being cached. The JVM is redirecting to the elasticsearch
servers.
squid.conf:
acl mynetwork src xxx.xxx.xxx.0/24
http_access allow mynetwork
http_port 80 accel defaultsite=
cache_peer parent 80 0 no-query originserver
#defaults
acl manager proto cache_object
acl localhost src 127.0.0.1/32 ::1
acl to_localhost dst 127.0.0.0/8 0.0.0.0/32 ::1
acl localnet src 10.0.0.0/8
acl localnet src 172.16.0.0/12
acl localnet src 192.168.0.0/16
acl localnet src fc00::/7
acl localnet src fe80::/10
acl SSL_ports port 443
acl Safe_ports port 80
acl Safe_ports port 21
acl Safe_ports port 443
acl Safe_ports port 8080
acl Safe_ports port 70
acl Safe_ports port 210
acl Safe_ports port 1025-65535
acl Safe_ports port 280
acl Safe_ports port 488
acl Safe_ports port 591
acl Safe_ports port 777
acl CONNECT method CONNECT
http_access allow manager localhost
http_access deny manager
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access allow localnet
http_access allow localhost
http_access deny all
#http_port 8080
hierarchy_stoplist cgi-bin ?
coredump_dir /var/spool/squid
refresh_pattern ^ftp: 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern -i (/cgi-bin/|?) 0 0% 0
refresh_pattern . 0 20% 4320
If anyone can help, it will be greatly appreciated.
