Need help creating a status panel using Heartbeat data
I am trying to partially recreate the example dashboard shown here:
In particular, I want to create a panel that uses a table, and I want the first column to be an up/down status column. This is the desired look:
What I am getting instead is this
These are the table settings
Use Lens -> Table -> Last Value
Thanks! That hint helped a lot, as well as realizing I have to set Rows to url.domain.
How do I add the little red/green indicators next to the monitor status, as shown on the Heartbeat monitor example?
I don't think we have markup yet in the Kibana Lens Table Yet...
But with 5 Minutes work you can have it :slight_smile:
First Create a runtime field based on the monitor.status
Here is the code
if (doc['monitor.status'].value == 'up')
    emit(Integer.parseInt("1"));
else
    emit(Integer.parseInt("0"));
Then add it as a metric
And set the colors
And Whullah ... not perfect but pretty close
Slightly Different Version (put space in label)
Thanks! I think this will do fine for now.
Hi again @stephenb,
Is is possible to add more than one drilldown to a Lens Table?
We have the URLs organized by environment (the typical dev, UAT (test), and production environments). So ideally clicking on certain URLs will take the user to the dev dashboard, clicking other URLs will take the user to the UAT dashboard, and so on.
Yes! But I am not sure how you will filter / direct to the proper env from each row.
You could create 3 drill downs to different URLS but the would be available for every row... there is not if/then logic in the drill downs not sure exactly how to do it.
Maybe you could a different type like the context menu... and just set 3 dev, UAT, Prod etc.
You should play with it.. .let me know what you figure out!!
The drilldowns can use values from your table
Or 3 Links to Dashboards
