Hi, Need to show popup in the elastic dashboard while clicking on any link/button. While clicking on link/button we need to call one external api to show the information in the popup. Is any feature available in elastic dashboard related to my requirement?
Have a look at Make dashboards interactive | Kibana Guide [8.11] | Elastic
Hi,Webservice call from Kibana dashboard this post requirement also same like my requirement, is any documentation available for this
I think the link I shared gives some ideas, no?
In case you missed it: Customize interactions with drilldowns | Kibana Guide [8.11] | Elastic
- URL — Navigates you from a dashboard to an external website. For example, a website with the specific host name as a parameter.
Hi dadoonet, Thanks for your reply. The link you shared is not relevant to my requirement, no need of opening external website from elk , I need to call one python api from elk dashboard itself and need to show that api response in the popup/dialog box.
and
sounds like contradictory to me.
The first says that you don't want to open a popup box.
The second says that you want to display results in the opened popup box.
So I don't know what you are looking for.
Hi dadoonet, You misunderstood my requirement. What i meant in my initial comment is -
- I want a popup.
- I want to show api response in that popup.
All this, I want to show on click of a button or hyperlink present in elk dashboard.
I think that drilldowns would help to do that. Did you try?
